[postgis-devel] [PostGIS] #931: [raster] ST_Mean
trac at osgeo.org
Fri May 13 15:00:48 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis raster | Version: trunk
Keywords: |
Changes (by dustymugs):
* status: new => assigned
Comment:
I've decided to go with your suggestion Pierre.
ST_Mean(rastertable text, rastercolumn text)
I realized as I was playing around with various possibilities that your
way was the only way that a tile would be loaded one at a time and not
overtly tax memory.
So, a set of variations of ST_Mean and ST_ApproxMean for handling large
sets of raster tiles:
1. ST_Mean(rastertable text, rastercolumn text, nband int, hasnodata
boolean) -> double precision
ST_Mean('tmax_2010', 'rast', 1, FALSE)
ST_Mean('precip_2011', 'rast', 1, TRUE)
2. ST_Mean(rastertable text, rastercolumn text, nband int) -> double
precision
hasnodata is set to FALSE
ST_Mean('tmax_2010', 'rast', 1)
3. ST_Mean(rastertable text, rastercolumn text, hasnodata boolean) ->
double precision
nband is set to 1
ST_Mean('precip_2011', 'rast', TRUE)
4. ST_Mean(rastertable text, rastercolumn text) -> double precision
nband is set to 1 and hasnodata is set to FALSE
ST_Mean('tmin_2009', 'rast')
Variations for ST_ApproxMean are:
1. ST_ApproxMean(rastertable text, rastercolumn text, nband int, hasnodata
boolean, sample_percent double precision) -> double precision
ST_ApproxMean('tmax_2010', 'rast', 1, FALSE, 0.5)
ST_ApproxMean('precip_2011', 'rast', 1, TRUE, 0.2)
2. ST_ApproxMean(rastertable text, rastercolumn text, nband int,
ST_ApproxMean('tmax_2010', 'rast', 1, 0.5)
ST_ApproxMean('precip_2011', 'rast', 1, 0.2)
3. ST_ApproxMean(rastertable text, rastercolumn text, hasnodata boolean,
nband is set to 1
ST_ApproxMean('tmax_2010', 'rast', FALSE, 0.5)
ST_ApproxMean('precip_2011', 'rast', TRUE, 0.2)
4. ST_ApproxMean(rastertable text, rastercolumn text, sample_percent
ST_ApproxMean('tmax_2010', 'rast', 0.5)
ST_ApproxMean('precip_2011', 'rast', 0.2)
5. ST_ApproxMean(rastertable text, rastercolumn text) -> double precision
nband is set to 1, hasnodata is set to FALSE and sample_percent is set
to 0.1
ST_ApproxMean('tmax_2010', 'rast')
ST_ApproxMean('precip_2011', 'rast')
Similar variations will be provided for ST_SummaryStats, ST_StdDev and
ST_MinMax and corresponding approximation functions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/931#comment:5>
