[postgis-devel] Raster: band stats api test taking 1.2Gb VM
Sandro Santilli
strk at keybit.net
Tue May 17 08:17:38 PDT 2011
On Tue, May 17, 2011 at 08:07:53AM -0700, Bborie Park wrote:
> I probably need to make the test raster significantly smaller, at
> least for what is sitting in trunk.
I think regress test is for testing correctness, not performance,
unless you can automate checking for speed or memory usage degradation
(which would be nice, but I'd still do as a separately triggered test)
As for input size there's likely the possibility for create rasters
using a set of function calls, so the repository remains smaller
(but I'm not sure this is what you were referring to with "smaller").
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
