[postgis-devel] Should we start using default args now?
Paragon Corporation
lr at pcorp.us
Tue May 17 16:08:04 PDT 2011
That's just the refentry id. We had to give all raster functions an id of
RT_ST though the functions just starts with ST_ to prevent page conflict
with geometry functions of same name.
Otherwise we'd have to include all the raster same named functions in the
geometry/geography section -- which I know you would REALLY like :)
BTW: I've taken the first dip and converted my ST_AsX3D to use optional
arguments -- so now I have just one instead of 2.
Waiting to see how this looks in the docs.
It looks like I can drop the function after I create the new one, so adding
it in the drop.sql.in.c works. Well I have to double check on 8.4, 9.0 but
can get away with it in 9.1.
If that works -- are people okay with me getting rid of all those extra
permutations of ST_AsGeoJSON, ST_AsGML etc. that I've always been eyeing to
remove with bated breath?
It shouldn't break anyones code since I'll make sure to maintain the same
public API.
Then I can attack raster code as well -- if raster folks don't mind me
stepping in their territory.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Tuesday, May 17, 2011 2:03 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Should we start using default args now?
RT_ST?
P
On Tue, May 17, 2011 at 10:41 AM, Paragon Corporation <lr at pcorp.us> wrote:
> I like that. Though we should start with Bborie's first (which
> doesn't require drop anything since they are so new)
> Many of the raster functions have 4 or 5 protos per function.
> So Bborie added about 10 (hmm maybe more but that's as high as I can
> count) new functions each of which has anywhere from 2-10
> permutations. -- to add up to a lot.
> For example:
> http://www.postgis.org/documentation/manual-svn/RT_ST_AsPNG.html
> Great functions by the way :)
> So I've been hesitant to document the ST_AsTiff, ST_AsJPEG and all the
> analytics if we are going to go default args.
> Thanks,
> Regina
> Paul Ramsey
> Sent: Tuesday, May 17, 2011 1:20 PM
> We can include DROP IF EXISTS at the front of the upgrade scripts
> (already do that do some extent) to clean out non-defaulted pre-existing
functions.
> P.
> On Mon, May 16, 2011 at 11:04 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> No CREATE OR REPLACE would not replace them. We would have to drop
them.
>> I was thinking about just new functions like the 100 some odd Bborie
>> just loaded on us :)
>> Sandro Santilli
>> Sent: Tuesday, May 17, 2011 2:01 AM
>> On Tue, May 17, 2011 at 01:01:13AM -0400, Paragon Corporation wrote:
>>> Now that Bborie has unleashed his load of functions; I'm not
>>> complaining, I did ask for it :)
>>> I was wondering if maybe we should start using default arguments at
>>> least for raster. Now that our minimum is 8.4 for PostGIS 2.0, this
>>> is now an option. Does it make sense?
>> If 8.4 supports them, I'm for it. Surely for new functions.
>> Old functions might need more verifications (does CREATE OR REPLACE
>> replace them ?).
>> --strk;
>> () Free GIS & Flash consultant/developer
>> /\ http://strk.keybit.net/services.html
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
