[postgis-devel] [PostGIS] #957: [raster] rt_asgdalraster regress test fails
trac at osgeo.org
Mon May 23 23:24:42 PDT 2011
Reporter: strk | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by robe):
Just to add to this. With a bit of fussing and doing a second make check
by ccding itno raster folder (and copying some missing dlls in my mingw
compile), I wwas able to get my pg 8.4.4 windows VC++ build to pass most
of the tests.
Failing 4 though -- this is with libgdal 1.8.0 rtm version.
rt_asgdalraster, rt_aspng, rt_asjpeg, rt_spatial_relationship
Are these the 4 others are having issue with? This is on a 32-bit windows
7 box.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/957#comment:20>
