[postgis-devel] [PostGIS] #957: [raster] rt_asgdalraster regress test fails
trac at osgeo.org
Tue May 24 07:48:44 PDT 2011
Reporter: strk | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Please try r7235, which should resolve the rt_asgdalraster, rt_aspng and
rt_asjpeg issues. I've refactored the existing regression tests from
attempting to validate the contents returned from the respective functions
to checking that the functionality is correct.
A new script testgdalraster ("make testgdalraster" in raster/test/regress)
has been added to test the output of rt_asgdalraster and related
functions. As the testgdalraster depends upon python (specifically
raster/scripts/python/rtgdalraster.py), you'll need to have psycopg2
installed. The testgdalraster scripts uses the gdalinfo utility to
validate the output rasters band checksums. In testing on both 32-bit and
64-bit environments with four versions of GDAL (1.6.3, 1.7.3, 1.8.0 and
1.9.0 r22409), the script testgdalraster runs correctly.
As for rt_spatial_relationship, I have no idea as to that function.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/957#comment:21>
