[postgis-devel] [PostGIS] #969: [raster] Inconsistent order of named args in ST_MapAlgebra
PostGIS trac at osgeo.org
Thu May 26 04:21:01 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Changes (by robe):
  * priority:  medium => blocker
Comment:
 I think this may be related to #967 because as BBorie said, he was able to
 make check work cleanly on PostgreSQL 9.0+ by remarking out ST_MapAlgebra.
 That said, I consider this to be a blocker since it would prevent
 PostgreSQL 9.0+ from working in same fashion as PostgreSQL 8.4.  I haven't
 tried that trick yet to confirm, but it fits the pattern.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/969#comment:3>
