[postgis-devel] [PostGIS] #1252: SRID appearing in ST_AsText for particular multipolygon
trac at osgeo.org
Sat Nov 5 10:29:33 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by robe):
I think it might be the dump not the st_union. Are you testing on 1.5.3?
You don't see the behavior on 2.0.0.
Also note in the script I gave you, the actual generated table is fine.
It after I run the combination of dump and union that things go get messed
up. you also can't replicate this in 2.0.0. My 2.0.0 seems to behave
correctly.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1252#comment:10>
