[postgis-devel] [PostGIS] #1252: SRID appearing in ST_AsText for particular multipolygon
trac at osgeo.org
Sat Nov 5 10:39:57 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by robe):
strk - FYI - just retired again on a1.5.3 database running the latest
3.3.2dev and I still get the same weird behavior. Now I fear it might be
a windows only bug.
Do you have a 1.5 install? I haven't compiled 1.5.4svn to see if the
problem is still there I'll try to do that later.
Make sure you are testing with the script I attached to this ticket
http://trac.osgeo.org/postgis/attachment/ticket/1252/weird_poly.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1252#comment:11>
