[postgis-devel] [PostGIS] #1320: typmod geometry type not changing in before trigger
trac at osgeo.org
Tue Nov 22 16:45:11 PST 2011
Reporter: robe | Owner: jomarlla@…
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Paul,
Sorry I've been testing two things. One is a bonafied bug in PostGIS
because it works fine for geography. I got my tests a bit mixed up. The
other is another demonstration of a use case that typmod doesn't work for.
So here is the geography equivalent and it does as expected.
CREATE TABLE b(gid serial primary key, geog geography(MultiPolygon,
4326));
CREATE OR REPLACE FUNCTION public.trigb() RETURNS trigger AS
BEGIN
NEW.geog = ST_GeometryN(New.geog::geometry,1)::geography;
RETURN NEW;
END;
$$ language plpgsql
VOLATILE;
CREATE TRIGGER trigb_before
BEFORE INSERT
ON public.b
FOR EACH ROW
EXECUTE PROCEDURE public.trigb();
INSERT INTO b(geog) VALUES('MULTIPOLYGON (((0 0, 10 0, 10 10, 0
0)))'::geography);
throws this error -- which is the right thing to do:
ERROR: Geometry type (Polygon) does not match column type (MultiPolygon)
CONTEXT: PL/pgSQL function "trigb" line 2 at assignment
geometry typmod seems to be missing this secondary check. The other issue
which I think is the one bothering the poster is something there by
design. I'll test with varchar on that to confirm and that is that
PostgreSQL does a signature check to make sure what you are trying to
stuff in a table can go there before it even gets to the trigger.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1320#comment:2>
