[postgis-devel] [PostGIS] #1320: typmod geometry type not changing in before trigger
PostGIS trac at osgeo.org
Tue Nov 22 17:04:14 PST 2011
 Reporter:  robe      |       Owner:  jomarlla@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
Description changed by robe:
Old description:
> This is the report posted on:
> http://www.postgis.org/pipermail/postgis-users/2011-November/031493.html
> I can reproduce on 8.4 and 9.1 running latest build of PostGIS 2.0.
> To reproduce:
> CREATE TABLE A(gid serial primary key, geom geometry(MultiPolygon,
> 23030));
> CREATE OR REPLACE FUNCTION public.triga() RETURNS trigger AS
> BEGIN
> NEW.geom = ST_GeometryN(New.geom,1);
> RETURN NEW;
> END;
> $$ language plpgsql
> VOLATILE;
> CREATE TRIGGER triga_before
>   BEFORE INSERT
>   ON public.a
>   FOR EACH ROW
>   EXECUTE PROCEDURE public.triga();
> -- this allows  a polygon which should not be legal --
> INSERT INTO a(geom) VALUES('SRID=23030;MULTIPOLYGON (((0 0, 10 0, 10 10,
> 0 0)))'::geometry);
> -- st_AsText POLYGON((0 0,10 0,10 10,0 0))
> Seem to have same issue with geography.
New description:
 To reproduce:
 23030));
 BEGIN
 RETURN NEW;
 END;
 $$ language plpgsql
 VOLATILE;
   BEFORE INSERT
   ON public.a
   FOR EACH ROW
 INSERT INTO a(geom) VALUES('SRID=23030;MULTIPOLYGON (((0 0, 10 0, 10 10, 0
 0)))'::geometry);
 Geography works as expected -see next 2 notes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1320#comment:3>
