[postgis-devel] [PostGIS] #1329: Change BOX3D to be SRID and dimension aware
PostGIS trac at osgeo.org
Sat Nov 26 10:32:06 PST 2011
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  blocker      |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 Discussion here
 http://www.postgis.org/pipermail/postgis-devel/2011-November/016216.html
 To be followed up after float to double #1328.
 As a consequence of this change, the following also needs to be done for
 backward compatibility.
 box3d_extent will be deprecated and possibly removed, though I think that
 might break some apps removing it.  I have one to test that theory.
 1) ST_Extent returns box3d just like ST_3DExtent currently does.
 2) Both ST_3DExtent and ST_Extent be changed to strip the SRID of the
 improved box3d type by default, with an optional argument  -- keep_srid
 (defaulted to false) for those like strk who really want it and want to
 override the behavior to make it true.
 All this stuff better not push out the release time beyond our slated
 February 2012 or I'll be steaming mad (at least mad for a week).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1329>
