[postgis-devel] [PostGIS] #1329: Change BOX3D to be SRID and dimension aware
PostGIS trac at osgeo.org
Sat Nov 26 10:46:05 PST 2011
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  blocker      |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Description changed by robe:
Old description:
> Discussion here
> http://www.postgis.org/pipermail/postgis-devel/2011-November/016216.html
> To be followed up after float to double #1328.
> As a consequence of this change, the following also needs to be done for
> backward compatibility.
> box3d_extent will be deprecated and possibly removed, though I think that
> might break some apps removing it.  I have one to test that theory.
> 1) ST_Extent returns box3d just like ST_3DExtent currently does.
> 2) Both ST_3DExtent and ST_Extent be changed to strip the SRID of the
> improved box3d type by default, with an optional argument  -- keep_srid
> (defaulted to false) for those like strk who really want it and want to
> override the behavior to make it true.
> All this stuff better not push out the release time beyond our slated
> February 2012 or I'll be steaming mad (at least mad for a week).
New description:
 Discussion here
 deprecate box2d (possibly get rid of it).  I think there is too much code
 out there that relies on box2d that getting rid of it is a pipe dream the
 moment.  So we might want to deprecate it now, remove it from the docs,
 and encourage people to not use it in a non-violent demonstration of
 disapproval.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1329#comment:1>
