[postgis-devel] [PostGIS] #1213: [raster] RT_Intersects test fails
Sandro Santilli
strk at keybit.net
Sun Oct 2 14:37:58 PDT 2011
> Reporter: strk | Owner: dustymugs
> Type: defect | Status: assigned
> Priority: medium | Milestone: PostGIS 2.0.0
> Component: postgis raster | Version: trunk
> Keywords: |
> Comment(by dustymugs):
> Replying to [comment:15 strk]:
> > I've updated gdal to !r23167 and the new failure (on the 32bit, with
> postgis r7931) is:
> > --- rt_intersects_expected 2011-10-01 13:46:55.000000000 +0200
> > +++ /tmp/pgis_reg_23053/test_58_out 2011-10-02 20:54:56.000000000
> +0200
> > @@ -218,7 +218,7 @@
> > 2.6|2|21|ST_LineString|t
> > 2.6|2|22|ST_LineString|t
> > 2.6|2|23|ST_LineString|t
> > -2.6|2|24|ST_LineString|t
> > +2.6|2|24|ST_LineString|f
> > 2.6|2|25|ST_LineString|t
> > 2.6|2|26|ST_LineString|t
> > 2.6|2|27|ST_LineString|t
> > We seem to be closer...
> Can you try the following on the 32-bit machine? The query is equivalent
> to the raster and geometry failing in the regression.
> SELECT ST_Intersects(
> ST_AddBand(
> ST_MakeEmptyRaster(3, 3, 0, 0, 1, 1, 0, 0, 0),
> 1, '8BUI', 1, 0
> ST_MakeLine(ARRAY[
> ST_MakePoint(-1.1, 1.1),
> ST_MakePoint(1.1, 1.1),
> ST_MakePoint(1.1, -1.1),
> ST_MakePoint(-1.1, -1.1),
> , 1);
> The query should result in TRUE.
strk=# SELECT ST_Intersects(
strk(# ST_AddBand(
strk(# ST_MakeEmptyRaster(3, 3, 0, 0, 1, 1, 0, 0, 0),
strk(# 1, '8BUI', 1, 0
strk(# ),
strk(# ST_MakeLine(ARRAY[
strk(# ST_MakePoint(-1.1, 1.1),
strk(# ST_MakePoint(1.1, 1.1),
strk(# ST_MakePoint(1.1, -1.1),
strk(# ST_MakePoint(-1.1, -1.1),
strk(# ])
strk(# , 1);
st_intersects
f
(1 row)
Sorry for not using trac, but firing up a web browser is really time
consuming for me. I really hope the newer trac will have mail-to-ticket
gateway (github has one).
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
