[postgis-devel] [PostGIS] #1052: Tiger Geocoder 2010 Geocode() "squishing" toward end of block
trac at osgeo.org
Thu Oct 13 12:36:47 PDT 2011
Reporter: mikepease | Owner: robe
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment(by darkblueb):
the shifting you are seeing is fundemental to the way the TIGER data is
laid out. Each block has a *max* street address, by design. When addresses
on a block are recorded, they use some part of the range, with left overs
for later..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1052#comment:18>
