[postgis-devel] [PostGIS] #1052: Tiger Geocoder 2010 Geocode() "squishing" toward end of block
trac at osgeo.org
Thu Oct 13 13:11:14 PDT 2011
Reporter: mikepease | Owner: robe
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment(by mikepease):
Hmm. So, if I understand this correctly, the "tohn" doesn't have the same
meaning as it's being used for by the geocoder.
I think the geocoder assumes the "tohn" is the highest address number that
actually EXISTS. But I think you're saying that the real definition of
this column is that "tohn" is the highest POSSIBLE address number, not
necessarily one that exists.
Am I understanding that correctly? If so, that seems like a fundamental
limitation to the precision of the Tiger geocoder. You get a house to the
correct block, but its location within that block can't be precisely
figured unless somehow the highest EXISTING house number is known. And
when the highest existing number is lower than the highest possible
number, it will follow this "squishing" pattern that we've been seeing.
I suspect my client won't be satisfied with that level of precision.
Do you know if this is prevalent throughout all the Tiger address data?
I wonder if there is any clever solution to this.
You could "cheat" if this condition is known to be true most/all of the
time.
For example, if tohn=3299 but you're pretty sure the real max is 3250,
then the offset from the end of the block could be roughly doubled.
3250 is at the 50% mark of the address range, but really at the far end of
the block. If the full block was 1000m and the geocoder originally says
the 3250 house is 500m from the start, you could scale that offset up to
1000m.
I guess the trick here is still knowing the actual highest address number.
What if an assumption was made that the "tohn" is generally higher than
the real highest number? Could scaling the offset produce *better* (even
if not correct) results?
Did any of that make sense?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1052#comment:19>
