[postgis-devel] [PostGIS] #1244: rev7982 link against GEOS 3.2.3 fails
trac at osgeo.org
Fri Oct 14 21:56:49 PDT 2011
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Mac OSX 10.4.11;
PowerPC arch;
Postgres 8.4;
trunk postgis snapshot; NOTE there are no intel dev libs on this machine
pbG42-2:/Users/Shared/srcs/postgis-2.0.0SVN jspace$ make
for s in liblwgeom libpgcommon regress postgis loader utils ; do \
echo "---- Making all in ${s}"; \
make -C ${s} all || exit 1; \
done;
---- Making all in liblwgeom
make[1]: Nothing to be done for `all'.
---- Making all in libpgcommon
---- Making all in regress
---- Making all in postgis
Makefile.pgxs:17: warning: overriding commands for target `install'
/Library/PostgreSQL/8.4/lib/postgresql/pgxs/src/makefiles/pgxs.mk:92:
warning: ignoring old commands for target `install'
Makefile.pgxs:63: warning: overriding commands for target `installdirs'
/Library/PostgreSQL/8.4/lib/postgresql/pgxs/src/makefiles/pgxs.mk:140:
warning: ignoring old commands for target `installdirs'
Makefile.pgxs:82: warning: overriding commands for target `uninstall'
/Library/PostgreSQL/8.4/lib/postgresql/pgxs/src/makefiles/pgxs.mk:164:
warning: ignoring old commands for target `uninstall'
gcc -no-cpp-precomp -isysroot /Developer/SDKs/MacOSX10.4u.sdk -mmacosx-
version-min=10.4 -headerpad_max_install_names -arch ppc -arch i386 -Wall
-Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement
-Wendif-labels -fno-strict-aliasing -fwrapv -bundle -multiply_defined
suppress lwgeom_debug.o lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o
lwgeom_functions_analytic.o lwgeom_inout.o lwgeom_estimate.o
lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_box.o
lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_geos.o lwgeom_geos_prepared.o
lwgeom_geos_clean.o lwgeom_geos_relatematch.o lwgeom_export.o
lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_triggers.o lwgeom_dump.o
lwgeom_functions_lrs.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
lwgeom_transform.o geography_inout.o gserialized_typmod.o
gserialized_gist_2d.o gserialized_gist_nd.o geography_btree.o
geography_estimate.o geography_measurement.o geometry_gist_selectivity.o
../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a
-L/usr/local/lib -lgeos_c -lproj -L/usr/lib -lxml2 -lz -lpthread -liconv
-lm -bundle_loader /Library/PostgreSQL/8.4/bin/postgres
-L/Library/PostgreSQL/8.4/lib -L/usr/local/lib -L/usr/lib -o
postgis-2.0.so
/usr/bin/ld: for architecture i386
/usr/bin/ld: warning ../liblwgeom/.libs/liblwgeom.a archive's cputype (18,
architecture ppc) does not match cputype (7) for specified -arch flag:
i386 (can't load from it)
/usr/bin/ld: warning ../libpgcommon/libpgcommon.a archive's cputype (18,
/usr/bin/ld: warning /usr/local/lib/libgeos_c.dylib cputype (18,
i386 (file not loaded)
/usr/bin/ld: warning /usr/local/lib/libproj.dylib cputype (18,
/usr/bin/ld: warning /usr/local/lib/libiconv.dylib cputype (18,
/usr/bin/ld: Undefined symbols:
_lwalloc
_lwfree
_lwgeom_typeflags
_lwrealloc
_lwtype_name
_lwgeom_distance_spheroid
_lwgeom_free
_lwgeom_is_empty
_lwgeom_length_spheroid
_lwgeom_release
_lwgeom_set_geodetic
_pglwgeom_deserialize
_pglwgeom_get_srid
_pglwgeom_get_type
_spheroid_init
_cstring2text
_gbox_copy
_getPoint2d_p
_getPoint3dm_p
_getPoint3dz_p
_lwerror
_lwgeom_add_bbox
_lwgeom_as_lwcollection
_lwgeom_as_lwcurvepoly
_lwgeom_as_lwpoint
_lwgeom_as_lwpoly
_lwgeom_as_lwtriangle
_lwgeom_count_vertices
_lwgeom_dimension
_lwgeom_force_2d
_lwgeom_is_closed
_lwgeom_is_collection
_lwgeom_parse_wkt
_lwgeom_parser_result_free
_lwgeom_set_srid
_lwgeom_to_wkb
_lwgeom_to_wkt
_lwline_construct
_lwline_get_lwpoint
_lwline_release
_lwpoint_as_lwgeom
_lwpoly_free
_pg_parser_errhint
_pglwgeom_has_m
_pglwgeom_has_z
_pglwgeom_serialize
_pglwgeom_set_srid
_ptarray_calculate_gbox_cartesian
_text2cstring
_distance2d_pt_pt
_error_if_srid_mismatch
_getPoint4d_p
_interpolate_point4d
_lwcircstring_construct
_lwcollection_construct
_lwcollection_construct_empty
_lwgeom_as_lwline
_lwgeom_as_lwmline
_lwgeom_simplify
_lwline_clip_to_ordinate_range
_lwline_crossing_direction
_lwmline_clip_to_ordinate_range
_lwmline_release
_lwpoint_construct
_lwpoint_getPoint2d_p
_lwpoly_construct
_ptarray_append_point
_ptarray_construct_empty
_ptarray_construct_reference_data
_ptarray_length_2d
_ptarray_locate_point
_ptarray_substring
_bytes_from_hexbytes
_lwgeom_from_wkb
_lwgeom_needs_bbox
_lwgeom_parser_result_init
_lwgeom_to_hexwkb
_lwpoint_to_latlon
_pglwgeom_drop_bbox
_pglwgeom_has_bbox
_azimuth_pt_pt
_gbox_expand
_gbox_init
_lw_dist2d_distanceline
_lw_dist2d_distancepoint
_lw_dist3d_distanceline
_lw_dist3d_distancepoint
_lwcollection_extract
_lwgeom_affine
_lwgeom_area
_lwgeom_as_lwmpoint
_lwgeom_as_multi
_lwgeom_calculate_gbox
_lwgeom_clone_deep
_lwgeom_count_rings
_lwgeom_drop_bbox
_lwgeom_drop_srid
_lwgeom_flip_coordinates
_lwgeom_force_3dm
_lwgeom_force_3dz
_lwgeom_force_4d
_lwgeom_force_clockwise
_lwgeom_geohash
_lwgeom_length
_lwgeom_length_2d
_lwgeom_longitude_shift
_lwgeom_maxdistance2d
_lwgeom_maxdistance2d_tolerance
_lwgeom_maxdistance3d
_lwgeom_maxdistance3d_tolerance
_lwgeom_mindistance2d
_lwgeom_mindistance2d_tolerance
_lwgeom_mindistance3d
_lwgeom_mindistance3d_tolerance
_lwgeom_perimeter
_lwgeom_perimeter_2d
_lwgeom_pt_inside_circle
_lwgeom_remove_repeated_points
_lwgeom_reverse
_lwgeom_same
_lwgeom_segmentize2d
_lwline_add_lwpoint
_lwline_as_lwgeom
_lwline_free
_lwline_from_lwmpoint
_lwline_from_lwpointarray
_lwline_removepoint
_lwline_setPoint4d
_lwpoint_free
_lwpoint_make2d
_lwpoint_make3dm
_lwpoint_make3dz
_lwpoint_make4d
_lwpoly_as_lwgeom
_lwpoly_from_lwlines
_lwtype_get_collectiontype
_lwtype_is_collection
_pglwgeom_get_zm
_pglwgeom_getbox2d_p
_pglwgeom_ndims
_pglwgeom_size
_box3d_from_gbox
_box3d_to_gbox
_gbox_new
_gbox_union
_gflags
_lwpoint_get_x
_lwpoint_get_y
_GEOS2LWGEOM
_GEOSBoundary
_GEOSBufferWithStyle
_GEOSContains
_GEOSConvexHull
_GEOSCrosses
_GEOSDisjoint
_GEOSEquals
_GEOSGeom_createCollection
_GEOSGeom_destroy
_GEOSGetCentroid
_GEOSHausdorffDistance
_GEOSHausdorffDistanceDensify
_GEOSIntersects
_GEOSLineMerge
_GEOSOverlaps
_GEOSPointOnSurface
_GEOSPolygonize
_GEOSPreparedContains
_GEOSPreparedContainsProperly
_GEOSPreparedCovers
_GEOSPreparedIntersects
_GEOSRelate
_GEOSRelatePattern
_GEOSSetSRID
_GEOSSingleSidedBuffer
_GEOSTopologyPreserveSimplify
_GEOSTouches
_GEOSUnion
_GEOSUnionCascaded
_GEOSWithin
_GEOSisRing
_GEOSisSimple
_GEOSisValid
_GEOSisValidReason
_LWGEOM2GEOS
_initGEOS
_lwgeom_buildarea
_lwgeom_difference
_lwgeom_geos_errmsg
_lwgeom_geos_error
_lwgeom_geos_version
_lwgeom_intersection
_lwgeom_split
_lwgeom_symdifference
_lwgeom_union
_lwmessage_truncate
_lwmpoly_free
_lwnotice
_pglwgeom_is_empty
_GEOSPrepare
_GEOSPreparedGeom_destroy
_lwgeom_extent_to_gml2
_lwgeom_extent_to_gml3
_lwgeom_to_geojson
_lwgeom_to_gml2
_lwgeom_to_gml3
_lwgeom_to_kml2
_lwgeom_to_svg
_lwgeom_to_x3d3
_GetProj4StringSPI
_getPoint_internal
_lwcollection_add_lwgeom
_lwmline_add_lwline
_lwmpoint_add_lwpoint
_lwmpoly_add_lwpoly
_lwproj_from_string
_lwpsurface_add_lwpoly
_lwtin_add_lwtriangle
_lwtriangle_construct
_pj_free
_point4d_transform
_ptarray_clone_deep
_ptarray_construct
_ptarray_flip_coordinates
_ptarray_isclosed2d
_ptarray_isclosed3d
_ptarray_merge
_ptarray_point_size
_ptarray_set_point4d
_lwgeom_homogenize
_lwline_measured_from_lwline
_lwmline_measured_from_lwmline
_lwpoint_clone
_lwpoint_getPoint3dm_p
_lwgeom_desegmentize
_lwgeom_has_arc
_lwgeom_segmentize
_lwgeom_clone
_lwgeom_makeType_full
_AddToPROJ4Cache
_GetPROJ4Cache
_GetProjectionFromPROJ4Cache
_IsInPROJ4Cache
_SetPROJ4LibPath
_lwgeom_transform
_pj_get_errno_ref
_pj_get_release
_pj_strerrno
_gserialized_from_lwgeom
_lwgeom_check_geodetic
_lwgeom_from_gserialized
_lwgeom_from_hexwkb
_clamp_srid
_geometry_type_from_string
_next_float_down
_next_float_up
_gidx_expand
_gidx_new
_gserialized_datum_get_gidx_p
_gserialized_get_gidx_p
_gserialized_set_gidx
_lwgeom_calculate_gbox_geodetic
_gbox_pt_outside
_gserialized_get_gbox_p
_gserialized_get_type
_lwgeom_area_sphere
_lwgeom_area_spheroid
_lwgeom_calculate_gbox_cartesian
_lwgeom_covers_lwgeom_sphere
_gserialized_datum_get_gbox_p
collect2: ld returned 1 exit status
/usr/bin/ld: for architecture ppc
/usr/bin/ld: warning can't open dynamic library:
/Developer/SDKs/MacOSX10.4u.sdk/usr/local/lib/libgeos-3.2.3.dylib
referenced from: /usr/local/lib/libgeos_c.dylib (checking for undefined
symbols may be affected) (No such file or directory, errno = 2)
geos::geom::LineSegment::~LineSegment()referenced from libgeos expected to
be defined in /usr/local/lib/libgeos-3.2.3.dylib
__ZN4geos4geom11LineSegmentD0Ev.eh referenced from libgeos expected to be
__ZN4geos4geom11LineSegmentD1Ev.eh referenced from libgeos expected to be
vtable for geos::geom::LineSegmentreferenced from libgeos expected to be
geos::io::WKBReader::read(std::basic_istream<char, std::char_traits<char>
>&)referenced from libgeos expected to be defined in
geos::io::WKBReader::readHEX(std::basic_istream<char,
std::char_traits<char> >&)referenced from libgeos expected to be defined
geos::io::WKBWriter::write(geos::geom::Geometry const&,
std::basic_ostream<char, std::char_traits<char> >&)referenced from libgeos
expected to be defined in /usr/local/lib/libgeos-3.2.3.dylib
geos::io::WKBWriter::writeHEX(geos::geom::Geometry const&,
geos::io::WKBWriter::WKBWriter(int, int, bool)referenced from libgeos
geos::io::WKBWriter::~WKBWriter()referenced from libgeos expected to be
geos::io::WKTReader::read(std::basic_string<char, std::char_traits<char>,
std::allocator<char> > const&)referenced from libgeos expected to be
geos::io::WKTWriter::write(geos::geom::Geometry const*)referenced from
libgeos expected to be defined in /usr/local/lib/libgeos-3.2.3.dylib
geos::io::WKTWriter::WKTWriter()referenced from libgeos expected to be
geos::io::WKTWriter::~WKTWriter()referenced from libgeos expected to be
geos::geom::GeometryFactory::getDefaultInstance() referenced from
geos::geom::operator<<(std::basic_ostream<char, std::char_traits<char> >&,
geos::geom::Coordinate const&)referenced from libgeos expected to be
geos::index::strtree::AbstractSTRtree::iterate(geos::index::ItemVisitor&)referenced
from libgeos expected to be defined in /usr/local/lib/libgeos-3.2.3.dylib
geos::index::strtree::STRtree::STRtree(unsigned long)referenced from
geos::simplify::DouglasPeuckerSimplifier::simplify(geos::geom::Geometry
const*, double)referenced from libgeos expected to be defined in
geos::simplify::TopologyPreservingSimplifier::simplify(geos::geom::Geometry
geos::algorithm::distance::DiscreteHausdorffDistance::distance(geos::geom::Geometry
const&, geos::geom::Geometry const&)referenced from libgeos expected to be
const&, geos::geom::Geometry const&, double)referenced from libgeos
geos::linearref::LengthIndexedLine::LengthIndexedLine(geos::geom::Geometry
const*)referenced from libgeos expected to be defined in
geos::operation::polygonize::Polygonizer::getCutEdges() referenced
geos::operation::polygonize::Polygonizer::getPolygons() referenced
geos::operation::polygonize::Polygonizer::add(geos::geom::Geometry
geos::operation::polygonize::Polygonizer::Polygonizer()referenced from
geos::operation::polygonize::Polygonizer::~Polygonizer()referenced from
geos::operation::valid::TopologyValidationError::getMessage()
geos::operation::valid::TopologyValidationError::getCoordinate()
geos::operation::valid::TopologyValidationError::toString() referenced
geos::operation::valid::IsValidOp::getValidationError() referenced from
geos::operation::valid::IsValidOp::isValid() referenced from libgeos
geos::operation::buffer::BufferBuilder::bufferLineSingleSided(geos::geom::Geometry
const*, double, bool)referenced from libgeos expected to be defined in
geos::operation::buffer::BufferBuilder::~BufferBuilder()referenced from
geos::operation::buffer::BufferParameters::DEFAULT_MITRE_LIMIT
geos::operation::buffer::BufferParameters::setQuadrantSegments(int)
geos::operation::buffer::BufferOp::getResultGeometry(double)referenced
geos::operation::overlay::snap::GeometrySnapper::computeOverlaySnapTolerance(geos::geom::Geometry
geos::operation::overlay::snap::GeometrySnapper::snapTo(geos::geom::Geometry
const&, double)referenced from libgeos expected to be defined in
geos::operation::overlay::OverlayOp::overlayOp(geos::geom::Geometry
const*, geos::geom::Geometry const*,
geos::operation::overlay::OverlayOp::OpCode)referenced from libgeos
geos::operation::geounion::CascadedPolygonUnion::Union(geos::geom::MultiPolygon
geos::operation::linemerge::LineMerger::getMergedLineStrings()
geos::operation::linemerge::LineMerger::add(geos::geom::Geometry
geos::operation::linemerge::LineMerger::LineMerger()referenced from
geos::operation::linemerge::LineMerger::~LineMerger()referenced from
geos::precision::CommonBitsRemover::addCommonBits(geos::geom::Geometry*)
geos::precision::CommonBitsRemover::removeCommonBits(geos::geom::Geometry*)
geos::precision::CommonBitsRemover::add(geos::geom::Geometry
geos::precision::CommonBitsRemover::CommonBitsRemover()referenced from
geos::precision::CommonBitsRemover::~CommonBitsRemover()referenced from
geos::geom::LineString::getCoordinatesRO() constreferenced from libgeos
geos::geom::GeometryFactory::createPoint(geos::geom::CoordinateSequence*)
constreferenced from libgeos expected to be defined in
geos::geom::GeometryFactory::createPoint(geos::geom::Coordinate const&)
geos::geom::GeometryFactory::buildGeometry(std::vector<geos::geom::Geometry*,
std::allocator<geos::geom::Geometry*> >*) constreferenced from libgeos
geos::geom::GeometryFactory::createPolygon(geos::geom::LinearRing*,
std::vector<geos::geom::Geometry*, std::allocator<geos::geom::Geometry*>
>*) constreferenced from libgeos expected to be defined in
geos::geom::GeometryFactory::createLineString(geos::geom::CoordinateSequence*)
geos::geom::GeometryFactory::createLinearRing(geos::geom::CoordinateSequence*)
geos::geom::GeometryFactory::createMultiPoint(std::vector<geos::geom::Geometry*,
geos::geom::GeometryFactory::getPrecisionModel() constreferenced from
geos::geom::GeometryFactory::createMultiPolygon(std::vector<geos::geom::Geometry*,
geos::geom::GeometryFactory::createMultiLineString(std::vector<geos::geom::Geometry*,
geos::geom::GeometryFactory::createGeometryCollection(std::vector<geos::geom::Geometry*,
geos::geom::GeometryFactory::createGeometryCollection() constreferenced
geos::geom::IntersectionMatrix::toString() constreferenced from libgeos
geos::geom::prep::PreparedGeometryFactory::create(geos::geom::Geometry
const*) constreferenced from libgeos expected to be defined in
geos::geom::Point::getCoordinatesRO() constreferenced from libgeos
geos::geom::Polygon::getExteriorRing() constreferenced from libgeos
geos::geom::Polygon::getInteriorRingN(unsigned long) constreferenced from
geos::geom::Polygon::getNumInteriorRing() constreferenced from libgeos
geos::linearref::LengthIndexedLine::extractPoint(double) constreferenced
geos::linearref::LengthIndexedLine::project(geos::geom::Coordinate const&)
typeinfo for geos::geom::LineStringreferenced from libgeos expected to be
typeinfo for geos::geom::LinearRingreferenced from libgeos expected to be
typeinfo for geos::geom::MultiPolygonreferenced from libgeos expected to
typeinfo for geos::geom::GeometryCollectionreferenced from libgeos
typeinfo for geos::geom::Pointreferenced from libgeos expected to be
typeinfo for geos::geom::Polygonreferenced from libgeos expected to be
typeinfo for geos::geom::Geometryreferenced from libgeos expected to be
vtable for geos::geomgraph::EdgeListreferenced from libgeos expected to be
lipo: can't open input file: /var/tmp//cclUyiva.out (No such file or
directory)
make[1]: *** [postgis-2.0.so] Error 1
make: *** [all] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1244>
