[postgis-devel] [PostGIS] #1243: ST_Distance_Sphere regress failure
trac at osgeo.org
Thu Oct 20 17:13:32 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Paul,
Any plans to fix this regression failure or is this something I should
note in the docs. I'd like to note it now before I forget if you do not
plan to fix. I can see why you would choose not to and in that event I'm
sure the pitch forks will be lining up on your next US speaking event :).
Thanks,
Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1243#comment:1>
