[postgis-devel] [PostGIS] #1247: ST_AsRaster aggregate function
trac at osgeo.org
Tue Oct 18 23:43:03 PDT 2011
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis | Version: trunk
Keywords: |
Description changed by robe:
Old description:
> Pierre,
> Not sure if this is what you had in mind when you said "Burn In" function
> in your talk. A common need I have which I am sure is that of many BI
> analysts is the need to show simple thematic maps in reports.
> What came to mind to me was an aggregate ST_AsRaster function that takes
> a set of geomval rows (or multicolumn geom, value) and builds a raster.
> Basically a reverse of the ST_DumpAsPolgons function.
> http://www.postgis.org/documentation/manual-svn/RT_ST_AsRaster.html
> This would make it trivial to do a query such as
> SELECT ST_AsPNG(ST_AsRaster(gval),300,300) As mymap
> FROM (SELECT ROW(ST_Union(geom), SUM(pop))::geomval As gval
> FROM sumregion
> GROUP BY region_name) As fii }}}
> Which is big considering many report writers allow their picture box
> controls to be bound to query fields. We might have a new crowd of BI
> analysts looking to get a piece of PostGIS action.
New description:
Pierre,
What came to mind to me was an aggregate ST_AsRaster function that takes a
FROM sumregion
GROUP BY region_name) As foo }}}
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1247#comment:1>
