[postgis-devel] How define a view that use a case operator for geometry field
aperi2007
aperi2007 at gmail.com
Fri Oct 28 13:33:45 PDT 2011
declaring the view using the bad code:
case
when a.codlinea<>'' then b.geom::geometry(LINESTRING,3003)
when a.codlineasoprasotto<>'' then c.geom::geometry(LINESTRING,3003)
end as geom
give this result
dbtopo=> \d v_elemento_divisorio
View "gb.v_elemento_divisorio"
Column | Type | Modifiers
oid | integer |
coddivisor | character varying(35) |
codtipo | character varying(128) |
codlinea | character varying(35) |
codlineass | character varying(35) |
geom | geometry |
instead declaring the view using the good code:
case
else c.geom::geometry(LINESTRING,3003)
end as geom
give this result
oid | integer |
geom | geometry(LineString,3003) |
Seem that postgis try to define it an else condition assigning it a
unknown "geometry" ?
Andrea.
Il 28/10/2011 20:21, Sandro Santilli ha scritto:
> I guess PostgreSQL can't assume the columns is
> geometry(LINESTRING, 3003)
> if one of the fields is possibly an unspecified
> geometry() ?
> See also \d theview, it should tell you the field type
> including geometry type (typmod).
> --strk;
> () Free GIS& Flash consultant/developer
> /\ http://strk.keybit.net/services.html
