[postgis-devel] CASE w/out ELSE hides typmod (was: How define a view that use a case operator for geometry field)
Sandro Santilli strk at keybit.net
Fri Oct 28 13:47:37 PDT 2011
On Fri, Oct 28, 2011 at 10:33:45PM +0200, aperi2007 wrote:
> Seem that postgis try to define it an else condition assigning it a
> unknown "geometry" ?
It's PostgreSQL, not PostGIS.
The same happens with any type, can be reproduced with something like this:
=# CREATE VIEW test1 AS SELECT
  CASE WHEN random() < 0.5 THEN 1::numeric(10, 0)
  END;
=# \d test1
       View "test.test1"
 Column |  Type   | Modifiers
 case   | numeric |
=# CREATE VIEW test2 AS SELECT
  ELSE 0::numeric(10, 0)
  END;
=# \d test2
         View "test.test2"
 case   | numeric(10,0) |
Maybe someone on pgsql-hackers can tell us more about this.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
