[postgis-devel] Geodetic issues
Chris Hodgson
chodgson at refractions.net
Thu Sep 1 11:37:06 PDT 2011
Paul, I think these questions are primarily for you - in light of a few
recent bug reports, I'm trying to figure out what is going in in
geography land (I apologize for being blissfully ignorant of much of the
work done so far).
- Is it illegal to have a point on the poles? From
ptarray_check_geodetic() in /liblwgeom/lwgeodetic.c
if ( pt.x < -180.0 || pt.y < -90.0 || pt.x > 180.0 || pt.y > 90.0 )
return LW_FALSE;
It seems kind wierd that it is ok to have a polygon the circumnavigates
the pole, but not a point on the pole?
- Am I right to think that the current "grumpy faces" in the function
support matrix:
http://postgis.refractions.net/documentation/manual-svn/PostGIS_Special_Functions_Index.html#PostGIS_TypeFunctionMatrix
Are pretty big hacks that have no hope for any kind of polar-encircling
data or other globe-wrapping data like for example satellite swaths? And
really the only way around these issues, which also could end up
addressing everything from isvalid to union is to write a geodetic-aware
equivalent to GEOS (or make JTS/GEOS "geodetic aware")? Are there any
plans for moving forward with something like that? I recognize there
would be a large amount of work involved (probably more than writing JTS
or GEOS as is, for planar geometries?). Is this the direction we would
want to go? Or am I wrong and these aren't big hacks but are "the way to
do it" and just need further tweaking to handle the ugly cases?
Thanks,
Chris
