[postgis-devel] Geodetic issues
Chris Hodgson chodgson at refractions.net
Thu Sep 1 13:35:57 PDT 2011
Thanks Bryce, I do believe you're right.  However that doesn't explain
this problem:
http://trac.osgeo.org/postgis/ticket/1170
I'll look a bit deeper.
Chris
Bryce L Nordgren wrote:
> On Thu, Sep 1, 2011 at 7:26 PM, Paul Ramsey <pramsey at opengeo.org
> <mailto:pramsey at opengeo.org>> wrote:
>     > - Is it illegal to have a point on the poles? From
>     ptarray_check_geodetic()
>     > in /liblwgeom/lwgeodetic.c
>     > if ( pt.x < -180.0 || pt.y < -90.0 || pt.x > 180.0 || pt.y >
>     90.0 ) return
>     > LW_FALSE;
>     > It seems kind wierd that it is ok to have a polygon the
>     circumnavigates the
>     > pole, but not a point on the pole?
>     It is weird, and I cannot access my last year self to figure out WTF I
>     was thinking doing strict less-than rather than less-than-equals. I
>     think it's just going to have to change.
> As I read it, that statement only returns false if y > 90.0 or y <
> -90.0; meaning that a point on the pole (exactly 90.0 or -90.0) would
> return true. Ergo, the stmt as is permits points on the poles. Am I
> missing something?
> Bryce
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
