[postgis-devel] Geodetic issues
Paragon Corporation
lr at pcorp.us
Thu Sep 1 14:54:55 PDT 2011
For what it's worth Chris -- it uses the
_BestSRID functions (_st_bestsrid(geography, geography) ,
_st_bestsrid(geography) to arrive at best SRID for both geometries then the
rest is just plain transformation.
I think at the Poles it uses stereographic something or other.
Paul can correct me if I misspoke.
Thanks,
Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Chris Hodgson
> Sent: Thursday, September 01, 2011 4:36 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Geodetic issues
> Thanks Bryce, I do believe you're right. However that
> doesn't explain this problem:
> http://trac.osgeo.org/postgis/ticket/1170
> I'll look a bit deeper.
> Chris
> Bryce L Nordgren wrote:
> > On Thu, Sep 1, 2011 at 7:26 PM, Paul Ramsey <pramsey at opengeo.org
> > <mailto:pramsey at opengeo.org>> wrote:
> > > - Is it illegal to have a point on the poles? From
> > ptarray_check_geodetic()
> > > in /liblwgeom/lwgeodetic.c
> > > if ( pt.x < -180.0 || pt.y < -90.0 || pt.x > 180.0 || pt.y >
> > 90.0 ) return
> > > LW_FALSE;
> > > It seems kind wierd that it is ok to have a polygon the
> > circumnavigates the
> > > pole, but not a point on the pole?
> > It is weird, and I cannot access my last year self to
> figure out WTF I
> > was thinking doing strict less-than rather than
> less-than-equals. I
> > think it's just going to have to change.
> > As I read it, that statement only returns false if y > 90.0 or y <
> > -90.0; meaning that a point on the pole (exactly 90.0 or
> -90.0) would
> > return true. Ergo, the stmt as is permits points on the poles. Am I
> > missing something?
> > Bryce
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
