[postgis-devel] build of rev 7813
maplabs at light42.com maplabs at light42.com
Tue Sep 6 09:36:25 PDT 2011
Hi All-
  liblwgeom.h used to exist, but is now.. where?
dbb at xps-420:/home/shared/srcs_xps/postgis_trunk/doc$ make clean
make -C html/image_src clean
make[1]: Entering directory
`/home/shared/srcs_xps/postgis_trunk/doc/html/image_src'
make[1]: Leaving directory
dbb at xps-420:/home/shared/srcs_xps/postgis_trunk/doc$ make pdf
/usr/bin/xsltproc ./xsl/postgis_aggs_mm.xml.xsl postgis.xml >
postgis_aggs_mm.xml
cat postgis.xml | sed "s/@@LAST_RELEASE_VERSION@@/2.0.0SVN/g" >
postgis-out.xml
make -C html/image_src images
gcc -g -O2  -Wall -Wmissing-prototypes -I../../../liblwgeom -c -o
styles.o styles.c
generator.o generator.c
generator.c:37: fatal error: liblwgeom.h: No such file or directory
compilation terminated.
make[1]: *** [generator.o] Error 1
make: *** [images] Error 2
dbb at xps-420:/home/shared/srcs_xps/postgis_trunk/doc$ cd ..
dbb at xps-420:/home/shared/srcs_xps/postgis_trunk$ make clean && make -j5
make -C doc clean
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/doc'
make[2]: Entering directory
make[2]: Leaving directory
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/doc'
rm -f postgis.sql postgis_upgrade.sql
for s in liblwgeom regress postgis loader utils raster topology; do \
                echo "---- Making clean in ${s}"; \
                make -C ${s} clean || exit 1; \
        done;
---- Making clean in liblwgeom
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/liblwgeom'
make -C cunit clean
`/home/shared/srcs_xps/postgis_trunk/liblwgeom/cunit'
rm -f stringbuffer.o measures.o measures3d.o box2d.o ptarray.o
lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwtriangle.o
lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwcircstring.o
lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o lwpsurface.o lwtin.o
lwout_wkb.o lwin_wkb.o lwout_wkt.o lwin_wkt_parse.o lwin_wkt_lex.o
lwin_wkt.o lwutil.o lwhomogenize.o lwalgorithm.o lwsegmentize.o
lwprint.o vsprintf.o g_box.o g_serialized.o g_util.o lwgeodetic.o
lwtree.o libtgeom.o lwout_gml.o lwout_kml.o lwout_geojson.o lwout_svg.o
lwout_x3d.o lwgeom_geos.o lwgeom_geos_clean.o lwspheroid.o
rm -f liblwgeom.a
rm -f liblwgeom.so
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/liblwgeom'
---- Making clean in regress
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/regress'
rm -rf /home/shared/srcs_xps/postgis_trunk/regress/00-regress-install
rm -f postgis.sql
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/regress'
---- Making clean in postgis
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/postgis'
rm -f postgis-2.0.so   libpostgis-2.0.a
rm -f postgis.sql uninstall_postgis.sql postgis_upgrade_20_minor.sql
legacy.sql uninstall_legacy.sql legacy_compatibility_layer.sql
rm -f lwgeom_pg.o lwgeom_debug.o lwgeom_accum.o lwgeom_spheroid.o
lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o
lwgeom_transform.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o
lwgeom_geos.o lwgeom_geos_prepared.o lwgeom_geos_clean.o
lwgeom_geos_sharedpaths.o lwgeom_geos_snap.o lwgeom_geos_split.o
lwgeom_geos_relatematch.o lwgeom_export.o lwgeom_in_gml.o
lwgeom_in_kml.o lwgeom_triggers.o lwgeom_dump.o lwgeom_functions_lrs.o
long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o geography_inout.o
gserialized_gist.o gserialized_typmod.o gserialized_gist_2d.o
gserialized_gist_nd.o geography_btree.o geography_estimate.o
geography_measurement.o geometry_gist_selectivity.o
rm -f postgis.sql.in uninstall_postgis.sql.in legacy.sql.in
uninstall_legacy.sql.in legacy_compatibility_layer.sql.in
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/postgis'
---- Making clean in loader
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/loader'
make -C cunit clean
make[2]: Entering directory `/home/shared/srcs_xps/postgis_trunk/loader/cunit'
make[2]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/loader/cunit'
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/loader'
---- Making clean in utils
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/utils'
make[1]: Nothing to be done for `clean'.
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/utils'
---- Making clean in raster
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/raster'
make -C rt_core clean
`/home/shared/srcs_xps/postgis_trunk/raster/rt_core'
rm -f rt_api.o
rm -f librtcore.a
make -C rt_pg clean
make[2]: Entering directory `/home/shared/srcs_xps/postgis_trunk/raster/rt_pg'
rm -f rtpostgis-2.0.so   librtpostgis-2.0.a
rm -f rtpostgis.sql
rm -f rt_pg.o
rm -f rtpostgis.sql.in rtpostgis.sql
make[2]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/raster/rt_pg'
make -C test clean
make[2]: Entering directory `/home/shared/srcs_xps/postgis_trunk/raster/test'
make -C core clean
make[3]: Entering directory
`/home/shared/srcs_xps/postgis_trunk/raster/test/core'
rm -f testapi testwkb
make[3]: Leaving directory
make -C regress clean
`/home/shared/srcs_xps/postgis_trunk/raster/test/regress'
rm -f -f rtpostgis.sql
make[2]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/raster/test'
make -C scripts/python clean
`/home/shared/srcs_xps/postgis_trunk/raster/scripts/python'
rm -f *.o
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/raster'
---- Making clean in topology
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/topology'
rm -f topology.sql
rm -f topology.sql.in
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/topology'
                echo "---- Making all in ${s}"; \
                make -C ${s} all || exit 1; \
        done;
---- Making all in liblwgeom
gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes
-I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -c -o stringbuffer.o
stringbuffer.c
-I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -c -o measures.o
measures.c
-I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -c -o measures3d.o
measures3d.c
-I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -c -o box2d.o box2d.c
-I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -c -o ptarray.o ptarray.c
In file included from ptarray.c:16:
liblwgeom_internal.h:19: fatal error: liblwgeom.h: No such file or directory
In file included from stringbuffer.c:40:
make[1]: *** [ptarray.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [stringbuffer.o] Error 1
In file included from box2d.c:6:
make[1]: *** [box2d.o] Error 1
In file included from measures.h:14,
                 from measures.c:19:
make[1]: *** [measures.o] Error 1
In file included from measures3d.h:14,
                 from measures3d.c:18:
make[1]: *** [measures3d.o] Error 1
make: *** [all] Error 1
dbb at xps-420:/home/shared/srcs_xps/postgis_trunk$ find . -name liblwgeom.h
dbb at xps-420:/home/shared/srcs_xps/postgis_trunk$ locate liblwgeom.h
/home/shared/srcs_xps/postgis-1.5.3SVN/liblwgeom/liblwgeom.h
/home/shared/srcs_xps/postgis2_trunk/liblwgeom/liblwgeom.h
/home/shared/srcs_xps/postgis2_trunk/liblwgeom/.svn/prop-base/liblwgeom.h.svn-base
/home/shared/srcs_xps/postgis2_trunk/liblwgeom/.svn/text-base/liblwgeom.h.svn-base
/home/shared/srcs_xps/postgis_trunk/liblwgeom/liblwgeom.h
/home/shared/srcs_xps/postgis_trunk/liblwgeom/.svn/prop-base/liblwgeom.h.svn-base
/home/shared/srcs_xps/postgis_trunk/liblwgeom/.svn/text-base/liblwgeom.h.svn-base
