[postgis-devel] liblwgeom.so
Sandro Santilli
strk at keybit.net
Mon Sep 12 23:34:53 PDT 2011
On Mon, Sep 12, 2011 at 11:39:42PM -0600, Paul Ramsey wrote:
> On Mon, Sep 12, 2011 at 7:28 PM, Paragon Corporation <lr at pcorp.us> wrote:
> >>> I feel like a better approach for the overall foss4g
> >>> ecosystem, and for our own internal work would be to have
> >>> those aspects of the API in OGR, which is already a system
> >>> level utility library.
> > +++++20 for this.
> > Guys the way I see it, the next big change we will have is taking full
> > advantage of the foreign data wrappers
> > functionality introduced in 9.1. This will be big for both raster and
> > postgis. OGR/GDAL seems like the most likely avenue
> > for taking advantage of that. That said -- our dependency on OGR/GDAL is
> > going to go from 50% to 100%
> FYI, I talked to Frank tonight, and he's totally open to having
> something like CleanGeometry in OGR. So that door's open if we want to
> go through it.
I've no problem moving in that direction, as long as I'll secure fundings
for the time it takes. Did you also ask about the malformed geometries ?
(single-point lines, open rings in polygons...).
Still, I don't think we should abandon the system-wide liblwgeom.
It'll make it easier to extend postgis (even just parsing canonical form).
It does make binaries smaller (2139kb to 568kb, library [945kb] excluded).
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
