[postgis-devel] [PostGIS] #1198: ST_Union fails on some sets of polygons. Snapping works around the problem
PostGIS trac at osgeo.org
Sat Sep 17 13:56:15 PDT 2011
 Reporter:  dmiranda                                       |       Owner:  pramsey
     Type:  defect                                         |      Status:  new
 Priority:  medium                                         |   Milestone:  PostGIS 2.0.0
Component:  postgis                                        |     Version:  trunk
 Keywords:  st_union topologyexception noded intersection  |
Comment(by dmiranda):
 Tried with downgraded geos to the ubuntugis unstable package.
 "POSTGIS="2.0.0SVN" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
 2009" LIBXML="2.7.8" USE_STATS (procs from 2.0 r7629 need upgrade)"
 Will handle this dataset, just like jgrocha said, but still gives the same
 error on the larger dataset.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1198#comment:3>
