[postgis-devel] [PostGIS] #1222: After the switch to SRID=0 topology tests fail
trac at osgeo.org
Thu Sep 29 03:29:46 PDT 2011
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Topology tests fail. Most are likely due to geometries with an explicit
SRID=-1 being compared with geometries with an implicit SRID=0.
Considering both -1 and 0 as "unknown" would likely fix these cases.
BTW, I suggest we have ST_Srid() return NULL for the unknown case.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1222>
