[postgis-devel] [PostGIS] #1735: ST_MakeValid: exception on geometry
trac at osgeo.org
Mon Apr 2 05:50:52 PDT 2012
Reporter: aperi2007 | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
So finally a valid GEOS bug. ST_IsSimple wasn't a good test but the one
performed by the attached CheckNoding.sql script is, and clearly shows
that UnaryUnion is failing to produce correct noding. There's a case of
linear and puntual interior/interior intersections between returned lines.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1735#comment:21>
