[postgis-devel] [PostGIS] #1735: ST_MakeValid: exception on geometry
PostGIS trac at osgeo.org
Tue Apr 3 08:29:33 PDT 2012
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.1
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by strk):
 To recap: the issue is with the heuristic used by UnaryUnion generating
 invalid noding.
 I've tested that iterating the noding procedure can eventually handle to
 correctly node.
 Such iteration could be implemented in PostGIS ST_MakeValid to improve
 likelyhood of succeeding.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1735#comment:22>
