[postgis-devel] [PostGIS] #1746: Upgrade scripts are not installing all functions
PostGIS trac at osgeo.org
Tue Apr 3 03:12:23 PDT 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  high                   |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Actually add ST_IsValid to that list.  Our upgrade script is generating
 ST_IsValid(geometry,int)
 but not ST_IsValid(geometry)
 Which I'm not sure the reason why we didn't make this use default args but
 doesn't perhaps because it is all implemented in c.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1746#comment:4>
