[postgis-devel] trunk == 2.0.1
Paragon Corporation
lr at pcorp.us
Thu Apr 5 16:38:39 PDT 2012
I took out my sloppy install approach from the docs since the pg_restore was
cleaner, but for those who have already screwed up and don't have the
patience to rerestore their backup.
You should be able to recover by:
running the
postgis_upgrade_minor.sql and raster_update_minor.sql files afterward.
People who used extensions -- you won't be able to run those scripts, but
you can run the drop function statements at the end.
That in theory is all you need to run to fix a faulty upgrade.
Hope that helps,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Paul Ramsey
> Sent: Thursday, April 05, 2012 7:17 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] trunk == 2.0.1
> Right, you can mostly get away with just slamming an
> unfiltered dump file onto the new database, subject to (a)
> being willing to ignore the many errors you will log and (b)
> the specific issues you note below.
> P.
> On Thu, Apr 5, 2012 at 3:36 PM, Brian Hamlin
> <maplabs at light42.com> wrote:
> > Hi All-
> > this was a startling thing to read!
> > A quick read of postgis_restore.pl says to me though..
> > IF you have old topology constructs or IF you have old WKT
> Raster or
> > IF you have custom, non-standard SRIDs in use or IF
> (unlikely) you are
> > trying to restore PostGIS function calls somehow from the .dump file
> > THEN you must use postgis_restore.pl
> > OTHERWISE no, it is not required
> > This is the start of a rather important FAQ I think !
> > best regards
> > Brian Hamlin
> > GeoCal
> > OSGeo California Chapter
> > 415-717-4462 cell
> > On Apr 5, 2012, at 1:55 PM, Paul Ramsey wrote:
> >> Angelos, see this
> http://gis.stackexchange.com/questions/22945/postgis-2-0-upgrade-prob
> >> lem-with-postgres-data
> >> Is there any way to warn people as they upgrade, because
> 2.0 is not
> >> backwards compatible with 1.5. They need to dump their database
> >> before they upgrade and run it through postgis_restore.pl while
> >> loading it back into 2.0.
> >> P.
> >> On Tue, Apr 3, 2012 at 1:17 PM, Angelos Tzotsos
> >> <gcpp.kalxas at gmail.com>
> >> wrote:
> >>> OK, no one can hear us :)
> >>> On 04/03/2012 11:15 PM, Paul Ramsey wrote:
> >>>> Yes. Sssssh :)
> >>>> thanks,
> >>>> P
> >>>> On Tue, Apr 3, 2012 at 1:15 PM, Angelos
> >>>> Tzotsos<gcpp.kalxas at gmail.com>
> >>>> wrote:
> >>>>> Hi Paul,
> >>>>> I assumed this is the final:
> >>>>> http://postgis.org/download/postgis-2.0.0.tar.gz
> >>>>> Angelos
> >>>>> On 04/03/2012 11:11 PM, Paul Ramsey wrote:
> >>>>>> Are all the versions numbers correct? What did you package off
> >>>>>> of? I haven't released the tarball yet...
> >>>>>> P.
> >>>>>> On Tue, Apr 3, 2012 at 1:09 PM, Angelos
> >>>>>> wrote:
> >>>>>>> On 04/03/2012 10:39 PM, Paul Ramsey wrote:
> >>>>>>>> Devs,
> >>>>>>>> I have tagged 2.0.0. I have not branched a 2.0 yet. I would
> >>>>>>>> like to hold 2.0 development on trunk until we do a 2.0.1
> >>>>>>>> release. At that point we can create a 2.0 branch
> and bring new
> >>>>>>>> features online in trunk.
> >>>>>>>> Uploading and preparing text now for release announcement.
> >>>>>>>> P.
> >>>>>>>> _______________________________________________
> >>>>>>>> postgis-devel mailing list
> >>>>>>>> postgis-devel at postgis.refractions.net
> >>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> >>>>>>> Hi all,
> >>>>>>> I have completed packaging of v2.0 for openSUSE.
> >>>>>>> Waiting the announcement to release the rpms :)
> >>>>>>> Regards,
> >>>>>>> Angelos
> >>>>>>> Angelos Tzotsos
> >>>>>>> Remote Sensing Laboratory
> >>>>>>> National Technical University of Athens
> >>>>>>> http://users.ntua.gr/tzotsos
> >>>>> Angelos Tzotsos
> >>> Angelos Tzotsos
