[postgis-devel] [PostGIS] #1750: Java JDBC build issues
PostGIS trac at osgeo.org
Fri Apr 6 01:09:12 PDT 2012
 Reporter:  fake    |       Owner:  delawen
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.1.0
Component:  java    |     Version:  2.0.x
 Keywords:          |
Comment(by chodgson):
 The management issue that remains is that we need valid links on the
 download page to the jdbc jar and javadocs ... The problem is that the
 rest of the site is relying on hudson to create and upload such artifacts,
 but the build for the java stuff isn't quite compatible with how
 everything else is working. It doesn't have to be hard to fix that, but
 there may be deeper issues that we may want to resolve - or not.
 I do feel that it doesn't make a lot of sense for the java/jdbc stuff to
 live in the same source repo as the rest of the (c-based) postgis code.
 Particularly since their life cycles are essentially unrelated at this
 point. Also, I personally don't use the jdbc code at all even though I do
 use java to connect to postgis regularly - just use asbinary and the jts
 wkbreader - but that just means I'm less motivated to do any work on the
 java build stuff myself.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1750#comment:5>
