[postgis-devel] XSLTPROCFLAGS - empty vs undefined
Sandro Santilli
strk at keybit.net
Sun Apr 8 08:22:41 PDT 2012
On Sun, Apr 08, 2012 at 11:13:20AM -0400, Greg Troxel wrote:
> I'm packaging 2.0 for pkgsrc, and having two small issues.
> (One is the lack of a single target to build main and docs; more later
> on that.)
> in doc/Makefile.in, there is this code:
> ifeq ($(XSLTPROCFLAGS),)
> XSLTPROCFLAGS=--nonet
> endif
> to set --nonet (which is indeed conceptually right), but I'm trying to
> avoid it right now because the mathml dtd is not packaged (probably
> because of this default-to-download bug in xsltproc).
> If the environment has "XSLTPROCFLAGS=", resulting in $XSLTPROCFLAGS
> being empty, as opposed to undefined, --nonet is still added.
I tought I successfully tested:
make html XSLTPROCFLAGS=
Did you ?
You could also try XSLTPROCFLAGS=--timing (for a less verbose approach)
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
