[postgis-devel] long-xact patch
Carlos Ruiz
cruizch at gmail.com
Tue Apr 10 13:34:40 PDT 2012
Hi to all,
I was reviewing the PostGIS long term locking functions to work with them
on the Mapserver/TinyOWS project, and I found a TO-DO in the CheckAuth
function.
So I write the necessary code into the long_xact.sql.in.c file to check if
the check_auth trigger exists into the PostgreSQL's system catalogs to
avoid the creation error.
I know this is a very little thing but here is the patch as a small
contribution to this great project for now.
Greetings from Guadalajara, México
*IC Carlos Ruiz*
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120410/aa1d79f7/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120410/aa1d79f7/attachment.obj>
