[postgis-devel] [PostGIS] #1764: overviews not marked as same alignment though main table is
trac at osgeo.org
Sun Apr 15 09:59:49 PDT 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.1
Component: raster | Version: 2.0.x
Keywords: |
Comment(by robe):
I'll send in a bit. I doesn't seem to happen in the same file. So you
have to test at least two files I think.
I had to run this query to find a candidate:
SELECT v1.filename As v1_filename, o1.rid As o1_rid, v2.filename As
v2_filename, o2.rid as o2_rid
FROM o_3_vhms As o1 INNER JOIN o_3_vhms As o2 ON
ST_SameAlignment(o1.rast,o2.rast) = false
INNER JOIN vhms As v1 ON ST_Within(v1.rast::geometry, o1.rast::geometry)
INNER JOIN vhms As v2 ON ST_Within(v2.rast::geometry,
o2.rast::geometry)
limit 1;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1764#comment:6>
