[postgis-devel] [PostGIS] #1764: overviews not marked as same alignment though main table is
trac at osgeo.org
Sun Apr 15 10:10:59 PDT 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.1
Component: raster | Version: 2.0.x
Keywords: |
Comment(by robe):
For the non-chunked version I had to change ST_Within to ST_Intersects. I
assume that is because the bounding box is a bit fatter so they overlap.
anyrate same query using intersects and within returns the same files at
issue. Just getting permssion before I can send the files.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1764#comment:7>
