[postgis-devel] [PostGIS] #1792: [raster] ST_Intersection returns false positives
trac at osgeo.org
Thu Apr 26 12:16:46 PDT 2012
Reporter: febus982 | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Software and DB Structure:
PostgreSQL 9.1.3
GEOS 3.3.2
GDAL 1.9.0
Table 1 (vector):
Single column (geom) - About 100.000 points geometries exported with GRASS
6.4.2 (v.out.ogr command).
Table 2 (raster):
Column 1 (rast): raster column
Column 2 (filename): filename
Raster is geotiff file imported with:
/usr/lib/postgresql/9.1/bin/raster2pgsql -s 4326 -a -Y -F -t 20x20
View 1:
SELECT v.geom, r.filename, st_value(r.rast, v.geom) AS value
FROM vector v, raster r
WHERE r.filename = 'file.tif'::text AND st_intersects(r.rast, 1,
v.geom);
I got multiple points in this view values (some are null values)
They are all aligned on same X and/or same Y.
If i materialize this view in a table using:
CREATE TABLE table AS SELECT...... (same command)
I got a bunch of notices in console:
st_intersects NOTICE: Attempting to get pixel value with out of range
raster coordinates:
View 2:
FROM geoserver_layers.z1 v, raster.raster r
WHERE r.filename = '2012042611_me.tif'::text AND st_intersects(r.rast,
1, v.geom) AND st_value(r.rast, v.geom) IS NOT NULL;
I Tried filtering out NULL values by adding "st_value(r.rast, v.geom) IS
NOT NULL" but I got some points missing instead of multiple points;
This happens in all forms of ST_Intersects
st_intersects(v.geom, r.rast, 1)
st_intersects(r.rast, 1, v.geom)
I Tried also changing tile size in raster2pgsql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1792>
