[postgis-devel] [PostGIS] #1792: [raster] ST_Intersect returns false positives (was: [raster] ST_Intersection returns false positives)
PostGIS trac at osgeo.org
Thu Apr 26 12:35:41 PDT 2012
 Reporter:  febus982  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.0.1
Component:  postgis   |     Version:  2.0.x
 Keywords:            |
Comment(by dustymugs):
 Since you're using points, the point is being converted to a raster for
 ST_Intersects(raster, band, geometry).  Hence the point becomes an area
 which may intersect with a raster that the point itself wouldn't.
 As for ST_Intersects(geometry, raster, band), the raster is converted to
 polygons before running a geometry, geometry intersects test.
 So by the looks of it, the problem is that in your query the
 ST_Intersects(raster, band, geometry) is operating by pixel (an "area")
 while ST_Value(raster, geometry) is essentially sticking a pin (your
 point) through the raster.  The ST_Intersects returns true while ST_Value
 returns NULL.
 You may want to use ST_Intersection(raster, band, geometry) instead of
 ST_Value.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1792#comment:1>
