[postgis-devel] [PostGIS] #1779: Make install is not installing comments sql files
trac at osgeo.org
Fri Apr 27 00:15:28 PDT 2012
Reporter: jomarlla | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by strk):
I noticed that comments are only built by "make" when building extensions.
The reason for this is that comments are made part of the postgis
extension.
@robe : what's the policy in this case ? we're basically duplicating files
around when extensions are enabled or is extension using the same base
files as the non-extension model ?
In other words, what should and should not be installed with extensions
enabled or disabled ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1779#comment:1>
