[postgis-devel] [PostGIS] #1955: Exception when 2 edges passed to ST_ModEdgeHeal() that are attached to the same 2 nodes
PostGIS trac at osgeo.org
Fri Aug 17 07:04:26 PDT 2012
same 2 nodes
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by wimned):
 Node 1 is to be removed, edges 1 and 2 are passed to ST_ModEdgeHeal().
 The exception is raised when ST_ModEdgeHeal wants to remove node 3
 Currently I'm working around by skipping the situations where 2 edges are
 atached to the same nodes.
 btw i'm using  version: POSTGIS="2.1.0SVN r10156" GEOS="3.3.4-CAPI-1.7.3"
 PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" TOPOLOGY
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1955#comment:3>
