[postgis-devel] [PostGIS] #1955: Exception when 2 edges passed to ST_ModEdgeHeal() that are attached to the same 2 nodes
trac at osgeo.org
Fri Aug 17 09:18:16 PDT 2012
same 2 nodes
Reporter: wimned | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.1.0
Component: topology | Version: trunk
Keywords: |
Changes (by strk):
* status: new => assigned
Comment:
Ok so 2 edges share _both_ nodes, but one of the node is also shared by
another edge.
What to do seems unambiguous, so this is a valid enhancement request.
I'm adding a testcase, and interesting enough the healing works IFF the
first node checked is only shared by the two edges
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1955#comment:4>
