[postgis-devel] [PostGIS] #2133: possible performance issue with ST_MapAlgebra
trac at osgeo.org
Wed Dec 5 06:34:32 PST 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Keywords: |
In the docs I have this example:
http://postgis.net/documentation/manual-2.1SVN/RT_ST_MapAlgebraExpr2.html
which is much faster now with r10798 upgrade
--on my 64-bit windows 2008 it used to take about 3.6 seconds
-- now it's down to 490ms (SUPER improvement)
WITH pr AS
-- Note the order of operation: we clip all the rasters to dimensions of
our region
(SELECT ST_Clip(rast,ST_Expand(geom,50) ) As rast, g.geom
FROM aerials.o_2_boston AS r INNER JOIN
-- union our parcels of interest so they form a single geometry we can
later intersect with
(SELECT ST_Union(ST_Transform(the_geom,26986)) AS geom
FROM landparcels WHERE pid IN('0303890000',
'0303900000')) As g
ON ST_Intersects(rast::geometry, ST_Expand(g.geom,50))
-- we then union the raster shards together
-- ST_Union on raster is kinda of slow but much faster the smaller you can
get the rasters
-- therefore we want to clip first and then union
prunion AS
(SELECT ST_AddBand(NULL,
ARRAY[ST_Union(rast,1),ST_Union(rast,2),ST_Union(rast,3)] ) As
clipped,geom
FROM pr
GROUP BY geom)
-- return our final raster which is the unioned shard with
-- with the overlay of our parcel boundaries
-- add first 2 bands, then mapalgebra of 3rd band + geometry
SELECT ST_AddBand(ST_Band(clipped,ARRAY[1,2])
, ST_MapAlgebraExpr(ST_Band(clipped,3),
ST_AsRaster(ST_Buffer(ST_Boundary(geom),2),clipped, '8BUI',250),
'[rast2.val]', '8BUI', 'FIRST', '[rast2.val]', '[rast1.val]') )
As rast
FROM prunion;
However I thought I could just replace my ST_MapAlgebraExpr with
ST_MapAlgebra so I'm not using a deprecated function, and while the output
looks the same as the original, my time for this query
is: 2320 ms which granted is better than the older timing of
ST_MapAlgebraExpr, but not nearly as good as the new timing of
ST_MapAlgebraExpr.
WITH pr AS
our region
'0303900000')) As g
get the rasters
prunion AS
clipped,geom
FROM pr
GROUP BY geom)
, ST_MapAlgebra(ST_Band(clipped,3),
As rast
FROM prunion;
Is there more to it than just swapping the function names?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2133>
