[postgis-devel] [PostGIS] #1694: PostGIS 2.0.0 does not build with clang
trac at osgeo.org
Wed Dec 5 23:53:04 PST 2012
Reporter: vince | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: trunk
Resolution: fixed | Keywords: history
Changes (by sharpie):
* cc: sharpie (added)
Comment:
Looks like this is still a bug.
I wasn't experiencing it earlier because Homebrew was using `/usr/bin/cpp`
which is a wrapper script on OS X that points to `llvm-gcc`. However, we
recently made some changes that cause `clang` to be used as the pre-
processor if it is also being used as the C compiler. After these changes,
I see the same errors Vince reported earlier.
A diff of the SQL scripts and Postgres extension files produced by `llvm-
gcc` as compared to `clang` (version 3.1) can be found here:
https://gist.github.com/4d943acc25f81b1ffe9c
(un-truncated versions can be found at
https://gist.github.com/4d943acc25f81b1ffe9c/366d6bd1379e80f1042adfe0b580653a97fd9e19)
The problems with Clang seem to be related to whitespace---it looks like
all the indentation is being stripped. The trunk version of Clang has
downgraded the errors to warnings, but the end result is still the same
and indentation is stripped.
Trying with GPP produces the following result:
https://gist.github.com/65057cf9fb6a56a5929c
GPP seems like a drop in replacement for the GCC pre-processor---except it
has a problem inserting URLs into the comments.
There are two unresolved issues here:
* Apple will be dropping `llvm-gcc` from XCode followig the next major
release, so it would be prudent to ensure Clang can be used as a pre-
processor.
* GPP provides a reasonable fall-back if supporting Clang is unfeasible.
However, there is currently no way to configure a build using `gpp` as the
preprocessor short of hacking `configure.ac` and re-running `autogen.sh`.
This is distasteful from a packaging standpoint.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1694#comment:25>
