[postgis-devel] [PostGIS] #1694: PostGIS 2.0.0 does not build with clang
trac at osgeo.org
Thu Dec 6 02:32:00 PST 2012
Reporter: vince | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: trunk
Resolution: fixed | Keywords: history
Comment(by vince):
Hi Sharpie,
Thanks for pointing out that /usr/bin/cpp is just a script wrapper in
10.8. I haven’t noticed.
Well, then the workaround I wrote for Macports is fragile and, as you
rightly emphasize, limited in time to the next XCode major release. Since
it seems utterly preposterous to build a gcc compiler just for cpp
availability, something must be done upstream.
However, I faintly remember that clang 3.2 has now a -traditional-cpp
option. Did you test it?
Cheers,
Vincent
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1694#comment:26>
