[postgis-devel] [PostGIS] #1531: raster2pgsql loader aborts
PostGIS trac at osgeo.org
Thu Feb 2 01:27:43 PST 2012
 Reporter:  andreasft            |       Owner:  pracine
     Type:  defect               |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.0.0
Component:  raster               |     Version:  trunk
 Keywords:  raster2pgsql loader  |
 raster2pgsql loader aborts processing for some rasters returning error:
 raster2pgsql: rt_api.c:4281: rt_raster_set_srid: Assertion `((void *)0) !=
 raster' failed.
 No pattern in which type of raster formats that crashes the loader.
 Tried two different ArcInfo Binary Grid Format. One works fine, the other
 crashes the import.
 Crashes
 http://bioval.jrc.ec.europa.eu/products/gam/download/access_50k.zip
 (200mb)
 Works fine
 http://sedac.ciesin.columbia.edu/gpw/global.jsp?file=gpwv3&data=pcount&type=wrk&resolut=half&year=90&version=gpw-v3
 (461 kb)
 Loader syntax crashing raster:
 raster2pgsql -s 4326 -I w001001.adf access > home/andreas/access.sql
 Processing 1/1:
 /mnt/pc258/prio_grid/source/access/access_50k/acc_50k/w001001.adf
 Warning 6: A dataset opened by GDALOpenShared should have the same
 filename
 (/mnt/pc258/prio_grid/source/access/access_50k/acc_50k/w001001.adf) and
 description (/mnt/pc258/prio_grid/source/access/access_50k/acc_50k)
 raster' failed.
 Aborted
 Loader syntax working raster:
 raster2pgsql -s 4326 -I /w001001.adf poptest > /home/andreas/poptest1.sql
 Processing 1/1:
 /mnt/pc258/prio_grid/source/gpw/lrc30p90/glp90ag30/w001001.adf
 filename (/mnt/pc258/prio_grid/source/gpw/lrc30p90/glp90ag30/w001001.adf)
 and description (/mnt/pc258/prio_grid/source/gpw/lrc30p90/glp90ag30)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1531>
