[postgis-devel] [PostGIS] #1531: raster2pgsql loader aborts
trac at osgeo.org
Thu Feb 2 02:37:15 PST 2012
Reporter: andreasft | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: raster | Version: trunk
Keywords: raster2pgsql loader |
Comment(by andreasft):
Information about each file from gdal_info:
Driver: AIG/Arc/Info Binary Grid
Files: c:\prio_grid\source\gpw\lrc30p90\glp90ag30
c:\prio_grid\source\gpw\lrc30p90\glp90ag30.aux
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\dblbnd.adf
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\gpw90.dbf
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\gpw90.prj
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\gpw90.shp
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\gpw90.shx
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\hdr.adf
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\log
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\prj.adf
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\sta.adf
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\w001001.adf
c:\prio_grid\source\gpw\lrc30p90\glp90ag30\w001001x.adf
Size is 720, 286
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,85.000000000114397)
Pixel Size = (0.500000000000400,-0.500000000000400)
Corner Coordinates:
Upper Left (-180.0000000, 85.0000000)
Lower Left (-180.0000000, -58.0000000)
Upper Right ( 180.0000000, 85.0000000)
Lower Right ( 180.0000000, -58.0000000)
Center ( 0.0000000, 13.5000000)
Band 1 Block=360x4 Type=Float32, ColorInterp=Undefined
Min=0.000 Max=16172424.000
NoData Value=-3.4028234663852886e+038
Metadata:
LAYER_TYPE=athematic
Files: c:\prio_grid\source\Access\access_50k\acc_50k
c:\prio_grid\source\Access\access_50k\acc_50k.aux
c:\prio_grid\source\Access\access_50k\acc_50k.rrd
c:\prio_grid\source\Access\access_50k\acc_50k.aux.xml
c:\prio_grid\source\Access\access_50k\acc_50k\dblbnd.adf
c:\prio_grid\source\Access\access_50k\acc_50k\hdr.adf
c:\prio_grid\source\Access\access_50k\acc_50k\log
c:\prio_grid\source\Access\access_50k\acc_50k\metadata.xml
c:\prio_grid\source\Access\access_50k\acc_50k\prj.adf
c:\prio_grid\source\Access\access_50k\acc_50k\sta.adf
c:\prio_grid\source\Access\access_50k\acc_50k\vat.adf
c:\prio_grid\source\Access\access_50k\acc_50k\w001001.adf
c:\prio_grid\source\Access\access_50k\acc_50k\w001001x.adf
Size is 43200, 21600
GEOGCS["WGS 84",
DATUM["WGS_1984",
Origin = (-180.000000000000000,89.999999999280021)
Pixel Size = (0.008333333333300,-0.008333333333300)
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000)
Lower Left (-180.0000000, -90.0000000)
Upper Right ( 180.0000000, 90.0000000)
Lower Right ( 180.0000000, -90.0000000)
Center ( -0.0000000, -0.0000000)
Band 1 Block=256x4 Type=Int32, ColorInterp=Undefined
Min=0.000 Max=108536.000
Minimum=0.000, Maximum=108536.000, Mean=1543.449, StdDev=2736.378
NoData Value=-2147483647
Overviews: 10800x5400, 5400x2700, 2700x1350, 1350x675, 675x338, 338x169,
169x8
5, 85x43
Metadata:
STATISTICS_MINIMUM=0
STATISTICS_MAXIMUM=108536
STATISTICS_MEAN=1543.4487145611
STATISTICS_STDDEV=2736.3775076303
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1531#comment:1>
