[postgis-devel] [PostGIS] #1529: postgis alpha3 extension fails to install -- documentation st_pixelaspolygon
PostGIS trac at osgeo.org
Mon Feb 6 12:40:42 PST 2012
st_pixelaspolygon
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 To me these simple checks should be done before we release an alpha for
 plain reason that I plan to build binaries to coincide with alpha, and it
 really screws up my tempo when extensions don't install since I can't
 really release the alpha.
 Yes I believe I have a ticket for that already -- #1532
 BTW: Can we have extensions build NOT require xsltproc?  We distribute the
 postgis comments files with the tar balls, so there isn't a reason to
 require it.  Besides if we do, I can't build extensions because I don't
 have xlstproc under mingw since it crashes a lot or really slows down my
 building.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1529#comment:5>
