[postgis-devel] [PostGIS] #1152: SRID_MAXIMUM should be raised, gserialized_get/set_srid () should be patched and typemod int too
PostGIS trac at osgeo.org
Thu Feb 9 06:53:15 PST 2012
  Reporter:  vince    |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  invalid  |    Keywords:  srid liblwgeom
Comment(by vince):
 Great! Thanks for taking this problem into account.
 If I’m not mistaken, the IGN has also anticipated the issue and adapted
 it's SRID to more reasonable values (around 10000). But, as you have
 pointed out, the problem remains for restoring out of a 1.5 table.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1152#comment:13>
