[postgis-devel] [PostGIS] #1152: SRID_MAXIMUM should be raised, gserialized_get/set_srid () should be patched and typemod int too
trac at osgeo.org
Fri Feb 10 08:59:42 PST 2012
Reporter: vince | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: invalid | Keywords: srid liblwgeom
Comment(by strk):
As of r9145 a dump-reload (required when upgrading to 2.0 anyway) would
try to change the SRID values and put them into a reserved zone. In
absence of clashes this would let you restore the dump fully, but you'll
need further interaction to update your SRIDS so to be moved _out_ of the
reserved zone.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1152#comment:14>
