[postgis-devel] Spatial relationships not defined should return null
Paul Ramsey pramsey at opengeo.org
Thu Feb 9 20:53:10 PST 2012
I'm not enthusiastic to change this behavior.
P.
On Thu, Feb 9, 2012 at 2:39 PM, Jose Carlos Martinez Llario
<jomarlla at cgf.upv.es> wrote:
> Hi list,
> According to the standards the spatial predicates which are not defined as
> st_touches (point , point) or st_overlaps (line, polygon) must return null.
> PostGIS returns false in those cases (trunk and previous versions too), so
> it is against SQL/MM.
> Should I open a ticket or this is the wanted behavior?
> Regards,
> Jose
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
